Hi,
I have been looking for a solution, even purchased couple of applications online to solve it but still stuck at this point.
Long way short; I have a 980 GB .MOV file and I am trying to burn it on a Blu-Ray as a movie, I tried it with Sony application; It isn't even rendering. When I change some options it sometimes renders but gave an error message at the end of the process. I also tried Ulead, it writes the data but with very low picture quality. No matter what I did I haven't been able to got a good picture quality. The Sothink application was the closest one amongs all; I got a perfect picture quality but a problem with the sound synchronization. I thought it might be because of the sound codes installed by some other applications, so uninstalled all codes and left the MOV codec, but yet, nothing different as an outcome...
May be some of you had such experiences and hoping you to at least share your ideas what could the problem be ? Could it be the size ? Is 980 GB too much to deal with ? or could it be a codec clash or something like that ?
Thanks in advance.
Regards
Results 1 to 20 of 20
1TB File are you sure ? a dual layer Blu-ray disk is only 50GB
what was the source of the file ? what is its running timeCHEERS GARRY -
First step is to re-encode to something that will fit on the media, best to pick a compatible codec. Don't bother to burn until this is done successfully.
Are you sure on those size numbers? 980 MB would seem far more likely than 980 GB, though this does not really change the essential problem. Re-encode is necessary unless PC playback only is acceptable, using the disk as simple data storage. That would assume the size is a misprint. -
Assuming it was truly 980GB, perhaps the best solution is to find something that can either:
(1) break the file into smaller chunks
(2) let you select a timeframe from a timeline on the video, then you can convert a 'chunk' of video at a time
Item #1 may be necessary if your file really is that big, as I doubt most consumer level apps and/or free apps are used to handling files of that size. Break off a piece and see if that works. -
Thanks for the responds.
Well, the file is 980 GB, just wanted to confirm. No typos. It is a 110 min movie file with very high quality shot.
And better to mention; File got a V210 codec.
@Nelson37: You mean to convert it to a different extension ? If so, I just need it to be in HD format without loosing any picture quality. I haven't been able to convert it with noticable quality loss.
@jg0001: I thought that way you mentioned but I am able to burn it to the disc with high picture quality as mentioned with sothink but when I do it the sound goes crazy in synchronization.
Just to clarify that disk has no problems hardware wise as I am able to burn any other media or data. -
When you have been able to convert this file, did it take several full days? Have never seen, or even heard of, any video file or any file of any kind with that kind of size, in general usage. Should take a LOONG time to even load into a program. Like hours.
You do not convert to a different extension, you convert to a different file type. Different file types often have different extensions, but not always. MPG1 and MPG2 both end in ".mpg", many types end in ".avi". For Blu-Ray in a standalone player, there are only a few acceptable filetypes. For PC playback from a data disk, you just have to shrink it to about 5% of its current size. This is going to involve a loss in quality.
Apparently this is basically an uncompressed Quicktime file. One solution offered was to use Quicktime pro to convert to uncompressed AVI. Hope you have some serious HD storage space.
This appears to be a professional format used in commercial applications, due to that and the ungodly size you are going to have a hard time converting it at all, to convert with minimal quality loss may well be impossible. Loss of audio synch seems to be a common problem.
I think you need Edtv on this one, maybe Johnny Malaria. Not too many folks here are likely to have had experience with such a monstrosity. -
You are looking for a good h.264 converter to compress your file. You could try free software like Ripbot264 to try convert the mov to blu-ray/avchd with h264 video.
Please also post the details from the mov. Video and audio codec, resolution, etc. Use mediainfo and open the mov and see what it says. -
here's a doom9 suggestion from a thread there.
I recently had a few of these given to me by the kid at work that has a mac, we were editing tv spots for our business , 30 seconds was over 1GB
solution was to use QT pro and convert to uncompressed avi
additional files needed were
(BlueFishCodec.qtx)
(QuickTime.qts)
(QuickTimeVR.qtx)
copied to C:\Program Files\QuickTime\QTComponents Folder--
And do you want a blu-ray video that works on blu-ray players? or just the video on blu-ray?
Originally Posted by oghss
http://www.fourcc.org/codecs.php
http://www.aja.com/products/xena/
as you will note the v210 codec (i'm not sure it's right to call it a codec) is an uncompressed video format supported by the video adapter linked to above. i am a bit perplexed as to why it's in a .mov container when it's evidently captured using a card that's windows oriented, but that's besides the point.
since it's uncompressed, i don't see why you would need a codec (COmpressor/DECompressor) to play it back, try a simple avisynth script, and see if that let's you load it into an encoder, or better yet, try mpeg streamclip, the .mov extension indicates that it's targeted to mac users, as does all the available software on Aja's site for working with said files, perhaps software that has it's origins on the mac platform will do the trick. -
@Nelson37 : Yea it took around 28 hours, even when the Sony Vegas application rendered it once in around 30 hours. I would be OK with minimal piture quality loss at this desperate point if the sound synchronization is ok. As for the uncompressed AVI option; I think I ve tried that and I wasn't even able to play the movie when I converted it. Thanks for the information though, appreciated it.
@Baldrick : I ll have a look at the file with the Media info application and will paste the outcome here. Will have a look at the RipBot264 as well. Thanks. FYI: I need the blu ray as a playable disc on blu-ray players.
@deadrats : I have no experience with Avisynth script or Mpeg streamclip, or even heard of, I ll have a look at those. Thanks.
It seems size could be a problem as it is not so common to work with such sizes but I mean how do the commercial companies or film producers deal with such files, I mean there has to be an application or at least a way to follow. Thanks for your useful inputs, hopefully I ll work this out. -
I think the commercial operators on files of this type would likely have it broken down into scenes that they would work on, rather than one massive file.
The uncompressed AVI solution was to have a different source to render from, this was suggested to avoid audio de-synch.
It was suggested that you would need some Serious Hardware to play either the original file, or the uncompressed AVI, due to bitrate considerations.
However, once the uncompressed AVI was re-compressed into something else, and h.264 would seem to be the only viable candidate, bitrate was substantially reduced and playback requirements were lowered.
So the suggested workflow would seem to be - convert to standard, uncompressed AVI, re-compress with h.264, then play. The original file is already an uncompressed AVI, but the complication of the MOV container seems to lead to the audio de-synch.
This workflow makes some sense to me from experience dealing with other, oddball containers wherein you must convert to a more standard container before continuing the process. The conversion to uncompressed, standard AVI should not affect quality. It should give you something that standard tools can work with. -
i'm just curious, how did you end up with such a file? -
I ll try the uncompressed avi solution to render, will write the outcome.
@deadrats: its a movie, shot by an hd camera.
I also got the outcome of the Media Info application gave, any points ring a bell for what the problem could be?
General
Complete name : H:\sss.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 860 GiB
Duration : 1h 51mn
Overall bit rate : 1 108 Mbps
Encoded date : UTC 2009-12-11 22:17:44
Tagged date : UTC 2009-12-12 04:59:38
Writing library : Apple QuickTime
Media/UUID : DC2FE888-9D34-49BA-9D19-25CFF65F4FD7
Video
Format : v210
Codec ID : v210
Duration : 1h 51mn
Bit rate mode : Constant
Bit rate : 2 809 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Bits/(Pixel*Frame) : 0.054
Stream size : 2.18 GiB (0%)
Language : English
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Unsigned
Codec ID : in24
Duration : 1h 51mn
Bit rate : 2 304 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.79 GiB (0%)
Language : English
Menu
Encoded date : UTC 2009-12-12 04:59:38
If the video is 2,809 kpbs and the audio is 2,304 kbps, how is the combined at 1,108 Mbps? Something doesn't add up.
Can you demux the streams, then recombine them into a more reasonable file? -
appears to be a mac format. apple pro res hd 10bit.
got a friend with a high end mac editing system?--
Plus the combined bit rate of 2,809kbs and 2,304kbs add up to 5113kbs.
If 1hr and 51mins = 111mins that = 6660secs
then
5113kbs / 8 = 639,125 (to make it bytes)
then
639,125 x 6660secs = 4.2GB
Why is the file 860GB (or 980GB) and not 4.2GB
A file size of 860GB and 1hr 51mins long should have a bit rate of 1Gbs not 5.1Mbs.
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 16:40 -
convert non blu ray movie to blu ray disc???
By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 18:51
